An internal function was called with a null pointer. This condition is not expected and is indicative of a possible memory corruption due to a software bug that needs engineering attention.
Provide information to technical support team on VMT configuration. Also, check the scalability limit and compare this with the current configuration.
Critical
Function %func% was called with a null pointer %arg%.
| Name | Type |
| func | String |
| arg | String |
